It is currently Fri Jul 11, 2025 9:22 am
PostPosted: Sat Jul 22, 2006 12:42 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
I'm contemplating the necks for the next two guitars, and I think I want to do a laminated neck - Mahogany with a maple-rosewood-maple center strip. What do folks do for the rosewood center strip. Do you just buy a set of sides and use those?
I would still cut out one piece necks like I do now, but from a laminated blank.
TIA,
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Sat Jul 22, 2006 4:06 pm
Mark, your idea of using a side for this sounds great but you can also resaw from an existing plank and bring it down to thickness with the drum sander or a jointer edger.
PostPosted: Sat Jul 22, 2006 9:14 pm
Sides are a good optionm and I've got several EIR sides for exactly that purpose - head over the the swap meet, BobC's got a number of orphaned sides (cocobolo, among other things) that would probably be pretty darn good choices for this kind of thing.
PostPosted: Sat Jul 22, 2006 11:17 pm
I reasaw mine then either run them through my planer, or my thickness sander. My center lams are usually curly maple, walnut, or purpleheart. Thickness runs from 1/8" to 1/2" .
PostPosted: Sat Jul 22, 2006 11:40 pm
Yeah, Check with any of the suppliers here for orphaned sides. Get the cheapest grade because all you see is the small edge.
PostPosted: Sun Jul 23, 2006 1:51 am
Bob C. has pre-cut rosewood lamination pieces ready to go. Two thicknesses. Check toward the bottom of his "necks" page.
PostPosted: Sun Jul 23, 2006 2:00 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Excellent!
Thanks guys!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Sun Jul 23, 2006 3:17 am
Mark,
If you wanted a wider rosewood center strip, here's another option.
There's a hardwood dealer local to me (Clarke Hardwoods) that has a LOT of EIR in fairly small planks -- just about the right size for sides, but every one of the ones I looked at were flatsawn. But you could get a piece like this and cut out sections, flip them 90* and have qs pieces for your insert, and then they could be pretty much any width you wanted (up to the width of the plank, of course).
Best,
Michael
Live to Play, Play to Live
